Terrain follow alt change speed
Hello, is there a way to have lidar terrain follow to be less aggressive when it senses objects below?
Trying to explain what i mean: i need to fly about 30 meters above ground in terrain follow auto mode, sometimes when flying the uav encounters some little cabins or fences and abruptly jumps up 3-4 meters and than drops 3-4 meters when passes the object, i would like to limit the speed at wich it changes altitude in order to be a little bit smoother.
Will try RNGFND_GAIN but i am not sure it works in auto missions.
thanks,
Corrado
Do you have resolve your problem ?
