Tera Ranger EVO 15m I2C
For some reason the object avoidance doesn’t work. The sonar range can detect the object distance correctly, but the rover doesn’t go around. Attached is the parameter file with AVOID_ENABLE = 1 and OA_TYPE =1FullParam_CubeBlack_EVO_OA_params.param (16.5 KB)
Object avoidance is working with following parameters for the Tera Ranger EVO:
AVOID_ENABLE = 3
AVOID_ANGLE_MAX = 1300
PRX_TYPE = 4
EK2_ALT_SOURCE = 1 (Use Range Finder)
Not sure if the last one above is required to be changed from 0 to 1
