I wanted to test the recently added support for Analog temperature sensor (AC 4.5) but I am unable to find the TEMP1_Parameters.
I am using CubeOrange.
Surprisingly these parameters are present when running SITL.
Update: Tested on other board as well. Same issue, can’t see the TEMP_Params
What Ardupilot version did you test this with?
I have tested on 4.6.0 Dev and 4.5.3-beta1
