Telemetry ESC BLHeli32
With additional wires if you use regular serial telemetry, and without additional wires if you use bidirectional DShot (which is what you should use). Note that you need to flash a BDShot-enabled firmware to use it.
Also, consider using BLHeli_S/Bluejay or AM32 instead of BLHeli32, because of this.
What do you mean by that? You can use AiO ESCs with it as well.
