I am (unsuccessfully) trying to use SITL to with a plane-tailsitter frame. The ultimate goal is to fly a bicopter (like the V22) but want to simulate first. Per the documentation, I am trying to use a tailsitter frame and set the q_tilt_type = 3.
As soon as I load SITL, the vehicle appears to be spinning, AHRS is bad, EKF is bad, and I cannot arm the system. I have not found any remedies as of yet – any suggestions?
One though was to try using quadplane then going back into params and setting q_frame_class = 10 - but this hasn’t seemed to work as I hoped. Will I need to make a custom frame with two motors?
Thanks!
