Hello everyone
I’m new to this forum and the hobby. I’m trying to assemble a quad with these components:
Pixhawk cube orange
T motor v2808(or v3008) with prop 8040
T motor f66a esc
6s, 5000 mah 75 c battery pack( tattu)
The max amp of v2808 with 8040 prop according to datasheet is 62 amps;
I have overheating problem of esc i suppose
After running motor at 50% throttle for 50 seconds one of the motors start stuttering and stops, and other motors stop at once and the esc sounds confused making beeps which i suppose indicates overheating
Unfortunately i couldn’t connect telemetry properly( i have connected telemetry wire of the esc to reciver pin of telemetry 1 but no luck recieving data)
Any ways, i was wondering what is the problem.
I don’t think overheating at 50% throttle would be normal.
I’m sure it’s not because of pid because i tested things in motor tab
I think may be esc caliberation is wrong, i currently caliberated esc with normal type selected in esc calibration tab
I tried dshots( with different speeds) but no luck running motors correctly at all.
I read the firmware to be blhelli32 for f66 which should support dshots but i can’t seem to get things right here
What should i do? Any help?
I have caliberated accels, radio and other things
But i think this problem only relates to esc and caliberation or smth else that i’m not familiar with
They are BLHeli_32 ESC’s so configure for Dshot600, don’t change it and troubleshoot from there. No ESC calibration is required for any Dshot protocol.
Post your parameter file, perhaps it’s just a configuration error. The most common is expecting Dshot to work on the main outputs.
What you should really do is flash the Bdshot version of firmware. Connect the ESC’s to the Aux outputs and configure it for Dshot600 and Bdshot.
I go to esc caliberation tab
Select esc type: normal
Press caliberation button
Proceed with the instruction
Esc and motors start beeping and finish caliberation
And i disconnect batter and replug fc to my laptop
You would only do this when using PWM ESC protocol. You have BLHeli_32 ESC’s capable of Dshot, that would make no sense at all.
After connecting to Mission planner what does this message say in the messages screen?
If it says this then it’s not configured for Dshot.
And again, post your parameters file.
Would you pls tell me what should i exactly do?
Roght now my esc is connected to main out pins of fc
You say i should connect them to aux out and go to esc caliberation tab and do the caliberation?
i’m really new to working with pixhawk and ardupilot. I’m so sorry if some of the things i say may make no sense!
I’m telling you to post a parameters file.
Then connect the ESC’s to AUX outputs 1-4 and configure the servo outputs.
Configure the ESC’s for Dshot, there are several parameters.
You should NEVER need to use the ESC Calibration Tab for any reason.
And this is what you need to see in that Banner Message: Read This And this
hello again
yes this is the message i see:
and this is the parameter file: parmeters list01.param (17.1 KB)
Update1: i did connect esc to aux 1-4 and changed servo outputs 9-12 to motor 1-4 and disabled servo outputs 1-4
changed the [MOT_PWM_TYPE] to number 6 which is dshot600
and right now i have running motors.
for now i ran motors at 80%-no props for 60 seconds and i have warm rather hot motors and i hear some kind of noise from motor as if the signal is oscilating or smth(by the way i’m testing in motor tab, no controller is involved)
the message is:
Progress but you missed some parameters:
SERVO_BLH_AUTO,1
SERVO_BLH_BDMASK,3840
SERVO_DSHOT_ESC,1
And you are correct to test them in the Motor Tab.
You will have to connect to BLHeliSuite to change a parameter in the ESC firmware. “Low RPM Power Protect” may have to be disabled with those kV motors.
Get it from here BLHeliSuite
thank you
i did changed those parameters
i have another problem for connecting telemetry wire of esc to fc
i have connected the telemetry wire to telemetry 2(or 1) of fc according to this:
so just one wire from telemetry of esc is connected to pin 3 of telemetry of cube
in ardupilot i have changed SERIALx_PROTOCOL=2
i don’t know the baudrates
Know how to do a Google search? In the future try something like this:
“arducopter esc telemetry”
You will see you are not setting those parameters correctly.
With Bdshot you will get ESC RPM anyway w/o the telemetry connection.
yes it’s really hot
but with the new modification Dave told me i think situation got better
i have tested 60% throttle for 1 minute and the temp checking by hand was 50 or so.
i will test 50% throttle for 5 minutes and 80% throttle for 5 minutes tomorrow to see the results.
