i am using the simpleTRK2b as a base and simpleRTK2b + simpleRTK2blite as a rover and moving baseline.
i managed to get a 0.05 accuracy of RTK in the Mission Planner, but the HDOP is 0.52 and won’t get lower than that. i’m excpecting to get HDOP of 0.10 at least with the accuracy i got using the RTK.
If you are chasing ‘sub-centimeter accuracy’ with Ardupilot using any GNSS module at all, you should know that the internal resolution of the location is already larger than 1 centimeter. This limits the location accuracy regardless of the input. Chasing better accuracy
Dataflash logs GPSA.XAcc or GPSA.AccX or something like that.
You sould also get some values using Mavlink telemetry, but only for GPS2 and only if you use mavlink2.
