RC6 is the one that saturates, So I guess ESC4 is the one to blame.
I am trying to simulate Striver mini VTOL model in Gazebo and SITL from Ardupilot. I could find the parameter of Striver mini VTOL. So, I could simulate Striver mini VTOL in SITL without Gazebo simulation. But I couldn’t find model.sdf and model.config for Gazebo. I would like to ask you to help me to find them. If there is no such model for Gazebo, I would like to ask you to help me to make one. Thank you.
Hello @Byeong_Yeon_Kim, unfortunately we do not have a Gazebo model for this aircraft. If the 3D CAD model for the vehicle and specifications are available then it is possible to create the model, but this is quite a large amount of work. You are welcome to look at some of the other examples in SITL_Models and use those as templates. Aside from rigging the model, the main work will be to estimate the aerodynamics parameters for the physics and then tune the aircraft AP params.
Thank you for your answer. It would be big help for me. I tried to find other similar examples with Striver Mini, which has 4 rotors for quad and 1 throttle and 3 control surfaces (aileron, elevator, and rudder each not elevon), but I couldn’t find one having all those features in SITL_Models. Could you recommend any other examples which have those features?
Hi everyone,
I recently got a Striver Mini +1 PNP and have added the following components:
- HereLink (for control and video)
- Emlid GNSS (for RTK positioning)
- Cube Orange (autopilot)
I still need to select the batteries, and I’d appreciate any advice on the best wiring setup to properly integrate these components.
Specific questions:
- Does anyone have a wiring diagram for this configuration?
- What battery setup would you recommend for good efficiency and endurance?
- Would a Mauch Power Module be a good choice for this setup? If so, which model do you recommend?
Any suggestions or references would be greatly appreciated. You can also reach me at gerencia@migeodb.com.
Thanks in advance! ![]()
I have built Striver mini VTOL 4+2 Quadplane and I am using different flight controller and PDB. However, ESCs are the ones came within the box. User Manual V3.0, 2024.04.
I was unsure what ESCs is being used but i am wondering if they’re capable of bdshot? Should I install the bdshot firmware of cube orange plus or normal one?
Also, is it recommended to install the latest release of arduplane, that is 4.6.1 for this drone or shall i stick with the version existed in the documentation of makeflyeasy (which is ArduPlane V4.3.3)
Thank you
You would have to determine what firmware is used on the ESC’s to answer that. The parameter file for that craft shows PWM (Q_M_PWM_TYPE,0). So, to use Bdshot it would have to be either BLHeli32, BLHeli_S (flashed with Bluejay) or AM32. Chances are it’s none of those.
@makeflyeasy1 posts on here occasionally,
I looked into their hardware documentation and could find any info about the ESC firmware. but thank you again for the good point Q_M_PWM_TYPE is set to 0 (in ArduPlane V4.3.3) in their param file. @makeflyeasy i hope you can confirm as using ESC telemetry capability is cool to have.
Also, will be nice if anyone can give an answer if its better to use Arduplane latest release 4.6.1 rather than the one find in the param file 4.3.3
MFE ESC, the customized BLHeli32 firmware used before, and the customized AM32 firmware used after BLHeli32 is shut down, theoretically support Bdshot mode, but we have not tested Bdshot mode extensively.
MFE’s ESC uses a customized version of AM32 firmware, which theoretically supports Bdshot mode, but we have not tested Bdshot mode extensively.
Thank you for answering. I will give it a shot and test the passthrough if the ESCs already hold this firmware.
Hi @makeflyeasy, I bought Mini Striver 4+2 and would like to do some simulations on Arduplane 4.6.0. I was wondering if you can help me out to get the physical model (RFX file) to import it in RealFlight Evolution? since I do not have the CAD file
Thank you
Hello! Do you have RFX files for other models? I want to see if this file is easy to export.
Hello!
Thank you for reaching back.
There are other files that can be found here:
- ARACE Griffin
- Other Released QuadPlanes by Ardupilot
Also, below you will find helpful links to understand more how to export such file from CAD: - Blog post creating a RealFlight model using Blender
- Description to achieve an RFX format file
- Tutorials to create a custom content for RealFlight
It will be really helpful to get such file so that we can test in SITL while visualizing it in RealFlight.
Hi everyone,
I’m facing a huge problem. The last VTOL we built was in 2021 using a Cube Orange Standard (not the Plus version). Now I’m building a Mini Striver 4+1 and (of course) the old firmware version 4.0.9 has a mismatch with the Cube Orange Plus, so I can’t create an exact copy of the first 2021 VTOL.
I was hoping to simply load version 4.0.9 and the .param files and have it ready to fly ![]()
Do you have any advice on where I can find an appropriate .apj firmware for the Cube Orange Plus and ready-to-use .param files for the Mini Striver 4+1?
I’d prefer not to make changes manually because I don’t want to risk messing up automatic functions like transition, etc.
Thanks a lot!
Sorry for this silly question, but i would appreciate your comment so that i dont burn my newly bought drone and flight computer ![]()
I bought a Mini striver 4+2 and will be using Cube orange plus. I have a 6S battery with 21000 mAh and a power brick mini (standard HV pm, that comes with CubeOrange plus). I want to double check if such power module is suitable for this battery, motors, and ESCs? If not, which power module i can buy that is compatible with the cube orange plus?
Thank you!
Anyone have a clue about this?
Hello, CubePilot Power Brick Mini is supported.
How can I reliably estimate Striver Mini crash rate? Has someone already done that? Maybe MFE has a number…?
E.g. I see two reports (2024, 2026) in this discourse of a Striver Mini motor failing during flight, leading to a crash, with cause of the failure still unknown. How to estimate overall reliability?
