Make your Companion Computer more stable, not suddenly reset by fluctuating power supply in fly time, reduce noise by the devices like ESC, motor, servo…
Stable Power Module is professionally designed with power IC 5V-5A to provide stable power for Companion computer as well as peripheral devices. It also has a built-in Serial port for connecting Companion computer and flight control. All connector in Stable Power Module is standard (JST GH and Molex Clik-Mate)
Technical detail
Weight: 21gram
Dimensions: 60 x 35 x 15 mm
Power Input: 7 to 36V power input (CLIK MATE 2.00mm)
Power Out: 5V/5A for
Rasp Pi (Jump 2.54mm)
Cooling fan, Peripherals (CLIK MATE 2.00mm)
Features: * Serial port (JST-GH)
Reverse voltage protection
Resist fluctuated, noise of electric power
Green Led Indicator Power
Compatible: * Compatible with all companion computer which have Rasp Pi pinout (2x20 2.54mm)
yes, Intel UpBoard have 40 pinout which same Raspberry Pi. So I think my stable power module is compatible with UpBoard. and my power is 5A-5V, it’s strong and stable for upboard.
