I want to equip a rover with a camera for FPV driving. Last time I did this the car rode on bumpy grass and the imagery shook alot. Even with various softer gel mountings and weights to increase the inertia, the forward view included every little bump.
Can anyone recommend a stabilized camera system that would smoothen out the view from a rover that drives over grass and sometimes dirt?
I may be wrong, but I would say this task is impossible to solve without a lot of technical effort.
Bumps and gravel produce different low frequency vibrations (or better: movements) with different amplitudes. So to dampen them out, if the car moves up over a 1cm bump for example, the stabilization system would have to move the camera down by the same amount at the same speed (active or passive).
And by up/down, I mean a linear movement not a tilt/pitch rotation.
Perhaps someone else knows a solution.
You should be able to mount a camera gimbal on the front of the rover for stabilisation. You could even hack mount a hand held mobile phone gimbal if you could make the mounting strong enough - most have a tripod screw mount in the bottom of the handle and just fix your camera to that.
This is an old thread and I’m new but I’m interested in the same thing… So I’ll chime in and throw this out to see what you guys think…
I have a rc car that has a gyro and it actually reacts quite well… Moving the vehicle on its axis the front wheels stay straight… This got me thinking…
I’m starting a boat build and I’ve been looking at servo gimbals like this :
Only problem is the gyro only works on one axis but for a single axis servo gimbal we might be able to make it work… Not dslr or iPhone kind of stability but I think it would be better… Definitely good for the yaw but roll would still be a problem…
I’m also thinking helli gyro but I don’t know alot about them…
The problem I am having is with the vertical component right at the camera mounting point. I’ve since learned that the best way to soften the blows of bumps in the road is to use a heavy car with a soft suspension. Real cars have this, otherwise every time we hit a small bump it would be sent directly up through our spine into our neck.
