I am trying to make my SRXL2 receiver to work with latest ardupilot copter.
I have Kakute F4 AIO V2 flight controller, and before I started messing with ardupilot, I checked on BetaFlight, and everything worked perfectly there, including telemetry etc.
I have receiver wired to T6 pin witch corresponds to SERIAL1 according to manual ?
And I did set it up to:
SERIAL1_PROTOCOL=23
SERIAL1_OPTIONS=4
But still nothing, what BAUD should be set up but I am assuming it doesn’t matter for this protocol.
Firmware I have is copter 4.1.0-FIRMWARE_VERSION_TYPE_DEV
What am I doing wrong ?
I am thinking that I might be missing some steps somewhere? Or some additional config?
Receiver connected to TX6 -> SERIAL1, that was working fine with BetaFlight.
Receiver is already bind and led is solid, but I still get nothing in here
It must be something simple, as I only just started looking at this, I probably missed something important
I have one of those and it works fine, so its either your configuration or its your FC setup. I’m wondering if its because there is no ALT config for RCIN and so the timer based input is always enabled. Are you able to build the firmware yourself? Also double and triple check you are connected to the TX pin and not the RX pin.
(sorry I couldn’t reply due to noobie limitation here)
I am not sure, I did reconnected it all (power and USB), but also I’ve set all unused Serials to -1, maybe that was it for now I only have GPS and Receiver connected
the only thing currently I can’t make work, is RSSI send back to receiver and to transmitter,
RSSI is visible HUD, but no matter what channel I am sending it to (tried 6-12) It’s not reflecting on my transmitter, but that might be due to my transmitter is not supporting it I think.
I do use type 3 as I’ve seen it somewhere. I have it on my HUD i Mission Planner. so it probably works.
just I think my transmitter doesn’t have option to display it.
But other than that. I am loving it ;).
GUI could be more user friendly, but other than that, it’s very good I like to have a control on anything I want.
Once again, thank you for your help
