Ok so looks like, reboot with power plugged messes it up and it needs to power down completely and restart to pick up SRXL2 again
So its worth bearing in mind that the SRXL2 RXās are quite power hungry - so make sure you are powering from somewhere reasonable (e.g. allow 200mA). Also the handshake protocol is a little dicey, although that doesnāt sound like your problem
I kind of looks like, when I reboot with ābuttonā in mission planner, it does not connect back to receiver
But when I do main power cycle without disconnecting usb
it comes back
currently I am using laboratory PSU as a power source so it has up to 5A, so thatās not a problem I thin.
If you donāt cycle the power the RX wonāt bootstrap - so thatās the problem
well there we go I guess that was my problem after all. I knew itās something simple I was/ wasnāt doing.
Thank you for you patience
Andyp1per Thank you so much for the support. I spent this afternoon getting my receiver workingā¦ Ironically my settings were all correctā¦ Wiring was good. But i didnāt have the latest firmware! Once I got the right firmware it all worked! (this is also my first post) Iām pumped to build a drone!
Has something changed in the Firmware? I canāt seem to get the Spektrum 4651T to communicate with the new Pixhawk Blue cubes. These are the ones with the orange architectureā¦ Am I missing something? I have tried on both pins and tries several serial ports and nothing worksā¦
HELP
Please post your parameters and firmware version
Firmware is Arducopter 4.0.7
Serial_Baud = 115
Serial_Option = 4
Serial_Protocol = 23
I have use these receivers before and was successful in setting it up, but for some reason I am have troublesā¦ I do know that the old Blue Cube use the Black Cube architecture, and the new Blue Cubes use the Orange architecture, not sure if that is messing things up or not. Iām stuckā¦
I have tried Telemetry 1, 2 GPS1, and the SBusO (Serial5) none of them would connect. I do get a solid light on my receiver so I am bound. I also have tried both (TX and RX) pins on the serial ports. Still no connection of the radio.
Ric
Any idea when they will be regularly supported?
4.1 is in beta at the moment
Iām trying this in 4.1 Copter and was only able to get it to work if I forced SRXL2 with RC_PROTOCOL = 256.
Using an AR10100T
Interesting, it does not look like the kind of receiver that requires bootstrap, but forcing SRXL2 essentially makes sure this kind of bootstrap works so cannot hurt.
Iāve got Pixhawk 4 and am looking for how to wire the srxl2 are people soldering straight onto the receiver and Pixhawk or am I missing something?
Need to be connected to a telemetry port / uart - so donāt use the RX or SPKT connector
But specifically how are people doing this? Soldering directly onto the receiver and pixhawk? Or is there some way of sourcing the connectors to make our own cables?
