Sony Alpha 7rV Gremsy Pixy S Gimbal Connection
Hello everyone,
I am currently trying to work on a Gremsy pixyS gimbal with the Sony Alpha 7rV - All cable plugged-in, HMDI works on herelink airunit but I am enable to make the cameratrigger function to work.
Is there anyone accustomed with that set up, and is able to help me with that. Apparently it may be another module to read the signal.
Hardware : Orange Cube - Herelink RC & AirUnit - Gremsy Pixy S & Sony Alpha 7rV.
If you need more information, do not hesitate to ask, as I am new in this field.
Thank you,
Jean-Eudes
Hi @Elk_Fish_Robotics ,
The gimbal does not support to control the camera, so you need a camera control module. In your case, you might want to look at AirPixel Entire 3 and Wiring set for Gremsy Pixy-S – AirPixel.cz
Hello Gremsy,
Thank you for the solution and sorry for the late reply.
Indeed, we finally made it work with AixPixel and the Gremsy set.
Thank you.
