Somebody help me about [ HEXA - H type ]
Hello. I want to build frame like this. I want to shorten middle arm HEXA H frame.
and I found this link https://github.com/ArduPilot/ardupilot/blob/master/libraries/AP_Motors/AP_MotorsMatrix.cpp
How can I get this frame type.
  1. If I upgrade firmware?
  2. If I change code with this code
Thank you all for taking time
Why you don’t use X frame
you can only downloaded from mission Planner X frame. :smile:
I think you can just use the standard Hexa frame type and settings, and your ATC_ACCEL_P_MAX and ATC_ACCEL_R_MAX will be different.
These PIDs will also be different Roll and Pitch, not locked like for a symmetrical craft.
ATC_RAT_RLL_P
ATC_RAT_RLL_I
ATC_RAT_RLL_D
ATC_RAT_PIT_P
ATC_RAT_PIT_I
ATC_RAT_PIT_D
Follow the tuning guides and Autotune should be able to sort it out.
I have to use H frame for R&D reason.
Thank you for reply raj
I chose hexa-h now. and I will try soon. I will tell you how it works. Thank you for realy Shawn
You say H frame but the pics are X frame - just be aware the motor rotations are different between X and H and the flight characteristics can be different (possibly bad) if you apply the wrong type (X or H) to the physical frame - like applying H frame type when the actual physical frame is an X.
hi haesolkim - were you able to get your H frame configuration working? interested in any updates you have w/ this project
