Hello Everyone,
I need some help in reversing the secure boot.
I was following the process of securing the firmware on my CubeOrange on Win11 using WSL1 Ubuntu 22.04 distribution. After following the process of building and uploading the secure bootloader, I flashed it using mavproxy.
Now to verify, I followed the Windows procedure of checking the string. It does show the secure string but now I am not able to boot up the device. As mentioned in the doc, I assume it is a bootloader cycle which is failing the boot check.
It would be great if someone to guide me through reverting the device back to its original state.
Note: I used Copter-4.3.5 to build the secure boot.
Thanks.
Update
I uploaded the Signed firmware again using the process mentioned in the documentation. This time the system did upload and boot as expected.
Have you flashed firmware signed with a key that’s onboard?
Yes, I generated the keys and used those to flash the firmware. To verify, I tried to install a firmware from the Mission Planner which helped to give the secure string in device manager
I would try standard update procedure with your signed firmware. Other than that it looks like your only venue is contacting dev team and getting help from the designated developer.
Alright, thank you for helping out.
I am also doing same process, but I am not able to flash the bootloader.
Once firmware become secure, I can’t connect it through MAVProxy/Mission Planeer/ QGC.
[45820.211631] usb 1-2: Product: CubeOrange±Secure-BL-v10
[45820.211633] usb 1-2: Manufacturer: CubePilot
[45820.212309] usb 1-2: SerialNumber: 2F0052001851313334373032
[45820.221937] cdc_acm 1-2:1.0: ttyACM4: USB ACM device
eshma@Myubuntu:~/coptor4.3.5/ardupilot-Copter-4.3.5$ mavproxy.py --master=/dev/ttyACM4
Connect /dev/ttyACM4 source_system=255
Log Directory:
Telemetry log: mav.tlog
Waiting for heartbeat from /dev/ttyACM4
MAV>
Pl
MAV> link 1 down
Can you please let me how you flashed bootloader?
Hey! @Vidya_Patil
Did you find the solution for that?
Hi, are you able to solve this issue?
I am also facing the same issue and want to solve it.
Can you please let me know if you find any ways for this?
Hi @shah_gaurang did you made any progress in this issue?
still not getting any replays and I am also looking for proper steps to follow
how are you flashing the bootloader?
I am following these steps. Linking Error into SecureBootloader
as I think it is related to memory linking. these steps are working fine with other flight controllers like kakuteh7, cubeorange. I am only getting errors in CubeOrangePlus.
