Greetings all. I am planning out my second build, and have extensively looked at flight controllers, settling on the Matek H743 Slim. There is a slight issue, however. I plan on using four ESCs, and the wiring diagram only shows a 4-in-1 esc. Is it possible to make this work, or should I look at another flight controller?
Thank you!
What about BEC? I see a 5v pad on the board but not a ground, if the pad in the image is what I’d use to replace BEC, what ground G pad do I connect to?
The pad in the image is a solder jumper with 2 positions that determines what voltage is available on the Vsw pad. There are ground pads all over that board. Like the one adjacent to the Vsw pad…
In case you’re not aware, most ESCs only need a signal and ground connection. Many ESCs include a 5V BEC which can be used to power other devices. You generally don’t want the 5V from the ESC BEC to be connected to the flight controller’s 5V line. So don’t connect the ESC’s red wire (between the signal and ground wire) to the flight controller. Connecting a 5V power supply (from an ESC’s BEC) to a line which already has 5V on it can (and usually does) cause problems.
Sorry if this is old news. I didn’t want you to make a mistake which is easy to avoid.
If not using that 4in1 ESC, attach your connector to the ESC’s to the FC 8P connector. For other signals (compass, GPS, R/C…) solder row headers, and for others (buzzer…) solder 28AWG silicone wire on the round solder pads.
If I remember well, for the first use with Ardupilot you must use ST programming tool.
