it shot up about 20ft straight up instantly and had to disarm and fall to the ground. i broke one arm and it is reprinting now. i am way overpowered with a 500mm frame, 2814 motors and 1237 props.
my minimum throttle is about 20% before the props spin. so, i have 400w down before i get lift. what should i use as ballast? a fishing rod and assistant till i get it tuned?
was stab mode the wrong mode? do i need to use alt hold? with ballast???
It is obvious we have a terminology barrier to get past. What do you mean by " I have 400w down before I get lift"?
We need a COMPLETE parts list and how much the aircraft weighs with EVERY THING installed including the battery.
Also post some pictures of the aircraft and post the data flash log files, either .log or .bin.
look at the current. it pulled 40A on that takeoff.
if this was normal STAB mode, does stab take off and shoot up to 30ft instantly? i didnt give it a chance to level off or anything since it was āout of my controlā i killed it instantly.
Yes, I see that. The battery canāt provide the current required w/o a large sag, this was my point. Some is expected but 10.3V for a 3S battery is below what many fly to with a depleted battery.
Had you flown this in an assisted mode (AltHold, Loiter) before this takeoff attempt? I ask because the MOT_THST_HOVER value (.457) came from somewhere.
only crashed it twice as i tried to get it to fly. what value should i knock that down to to let it retune?
.39 is default, that should do. Also, how did you arrive at the MOT_SPIN_ARM/MIN parameter values? Iām not saying they are wrong just that most everything else looks to be at default. And before flying again definitely set the initial tuning parameters for the prop/battery size. Use the Alt>A plug-in in Mission planner and enter the values manually.
Generally yes. But I wonder why they donāt start until 19%. What ESCās are they? Why donāt you set these to 0 and try the motor test again:
MOT_PWM_MAX,
MOT_PWM_MIN,
I thought you were suggesting No name ESCās and you really are if these are what you have. I would suggest at the next re-build opportunity to replace those with some better quality BLHeli firmware ESCās.
There are 2 versions of these ESCās. Red shrink wrap and yellow shrink wrap
Are 12-inch propellers the suggested size for this motor?
Any signs of heat at the motors?
I believe 10-inch (11-inch max @ 3S) propellers do better.
Did you do a successful ESC calibration?
