Hello all, I am looking for a Small size board (30x30mm) AIO (all in one) compatible with ardupilot to assemble and small and super-light autonomous copter. Also I would need a GPS
It’s in a small form factor which I really like. I have the same gripe as Kenny about the i2c pads though.
On GPS I use the u-blox F9P from Sparkfun GPS-RTK2 board. It’s one of the smaller breakout boards for that chip but might still be a bit bigger than what you want in your copter.
Did you have to do anything with the F9P?, or was it completely plug and play?
I’ve been waiting to hook up the M9N from sparkfun, as i don’t have ucenter on my laptop, but want to try it out.
I have flown on the MATEK F405 and also use the Omnibus F7. The F7 flys Ardupilot great with the BN-880 GPS/Compass and the Zoon V2/V2 Radios (similar to 3Dr SIK radios). There are definitely some gotchas if you are used to betaflight when configuring to Ardupilot. I had to do some strong google-fu to get the aircraft working correctly, but put together the attached guide of my notes… hopefully it helps.
Most of my effort with it has been spent in tackling the learning curve to supply RTCM from an on-site RTK base and then using moving baseline dual-F9Ps on my rover for yaw/heading (but I assume you can just use compass on most copters). Lots of great threads here and external resources we can link you to if needed!
