Skydroid H12- Solution for long rang UVA
SkyDroid H12 series uses newest Qualcomm Snapdragon 625 processor, equipped with an Android embedded system and advanced SDR technology and super protocol stack, making the image clearer, lower the latency, longer distance, stronger anti-infection, whether it is drones, robots, industrial control equipment, etc. can be applied,It is used to remotely operate helicopters, fixed wings, multi-rotors, vehicles, ships, etc. for video/ image transmission (camera optional), data transmission, telemetry, and control drone flight.
Recently got Skydroid H12.
Ran transmitter firmware update.
Post update, i am receiving frequency maching failed error, while trying to bind receiver
Anyone faced similar issue, please help
About the issues, please kindly contact us at sales01@skydroid.xin. Our team will help you solve it. And thanks for your attention of our Skydroid.
Can the H12 be connected to other devices (GNSS base station, laptop running Mission Planner)? Either via USB or bluetooth?
@RSUAS
had success on or could able to connect H12 transmitter with mission planner running on laptop using Bluetooth as SkydroidT12 done.
i couldn’t able to do that.
Hi! Maybe somebody know the answer. I got H12 and FULL HD gimbal camera (for H12).
But actual video quality is more like 640 X 480 (or even lower), when camera connected to H12.
Changing of “size” in H12 settings doesn’t change anything - in all modes, SD, HD and Smother, video looks same. Any other image settings like “brightness” e.t.c has no effect as well on image.
Video written to SD card is FULL HD. So, issue is only with video broadcast
No luck. The H12 transmitter came with the K1 Swan H-wing, and I have no intention of using it for other models. It just doesn’t seem usable, connectable, or reliable.
@RSUAS what video quality you are getting from camera ? My camera is full HD but quality is very bad.
I’m not really using the camera, as I didn’t find a great way to overlay it on Mission Planner.
How do we benefit from the google play mission planner? A separate Sik Radio telemetry works on the USB type C OTG port. hmm, kind of overkills if cannot connect wirelessly with UA directly without using Sik Radio. A normal tablet with traditional RC for personal use and for work did well too.
Does anyone know how to connect/wire a camera to the RC air unit? The user manual does not contain a diagram of the connection. then the seller sells it with a camera.
Hello everyone,
I recently purchased the Skydroid H12 and I’m trying to connect it to a Radiolink Crossflight flight controller. I’m facing some challenges with getting them to work together, and I was wondering if anyone here has experience with this combination or could offer some guidance.
Here’s what I’ve done so far:
  1. I successfully connected the Mission Planner running on the Skydroid to the flight controller.
However, I’m currently struggling to establish telemetry connectivity. If anyone has insights into how to make these two components work seamlessly together or if you know of any alternative flight controllers that might be easier to integrate, I would greatly appreciate your assistance.
Thank you in advance for any help or advice you can provide.
Best regards, Felipe Roman
Hi, did you find any solution to this?
