I built up my first rover - with two motors (left / right)
Configuration is set to
servo 1 => function 73 (left)
servo 3 => function 74 (right)
If I arm now and use stick YAW - both motors turn (depending on left/right) one motor forward and one motor backward. Direction is correct. If I move stick to left, right motor forward, left motor backward.
fine
But
a) how can I “drive” forward or backward?
b) Throttle stick seems to be “disabled” - if I set from low to high - not happens - no movements
I believe, I forgot some configuration settings
BTW: inside calibration screen - all stick movements are ok
Hi Kenny,
yes based on this topic it’s solved. Now I’m struggling with forward/backward driving.
I’m using MODE2 an my throttle stick for speed (0 (stop) stick is down, 100(up)) for speed, steering, with the right stick.
Unfortunately, I can’t drive backward. Mhm, seems next misconfiguration or I misunderstand this configuration at all
Ardurover expects a spring loaded throttle, so you can drive backwards. So either activate the spring for the left stick, or change the rcmap, pitch<>throttle, so you can do all driving with the right stick. This is what I do. I then use the left stick for gimbal control, where the sticky throttle is useful for permanent tilt.
I have mine the same as @count74 does. And in manual, I can drive forward or backward by moving the throttle control (left stick that is spring loaded) from center, while steering with the right stick. I have actually never tried going in reverse when in Steering mode (where the autopilot is actually controlling the outputs). I will have to try that the next time I use my mower.
It will reverse in Steering Mode. It will be sluggish though. I do it with my boat on accident sometimes. I forget to take it out of Steering and into manual.
The turning rate in reverse is far different in steering than manual. Rudders don’t turn as fast and speed is less than manual due to parameters. I’ll have to try Acro one of these days. I do mostly survey grids and periods of loiter with it and have not got around to it. The more
I think of it when I first started using the boat Acro was not available to me which probably explains it
That’s awesome! I went to Youtube to thumbs up and I see I already had and subscribed to your channel! It must have been a while back because I didn’t remember seeing it. That looks like a nice machine. It is definitely screaming for AUTO mode!
I still do not understand how rover will move front and back. In ardupilot servo only 2 channels are defined for left and right turn.
There is No definition for front and back like throttle or anything. Where should I get that option or how to do that??
Think of center stick as neutral. Raise the stick it goes forward, lower the stick it goes backwards. To turn it commands one side to go slower/faster than the other.
