It has same shitty gimbal as on all previous products or you’ve made fixes to it?
All your cameras ZR10, M8 Mini has issues on heavy drones so make them useless…
I’m not sure what the exact size the gimbal you mentioned is. According to the pictures, it obviously use bigger motors and dampers than A8 mini / ZT6.
Following the firmware update, I noticed that the AI tracking functionality is no longer working as expected. Despite my best efforts to troubleshoot the issue, I have been unable to resolve it.
I have checked the settings, ensured compatibility between the firmware versions of the ZT6 and the AI module, and attempted recalibration as per the provided documentation. However, the AI tracking remains non-functional.
If there are any known issues with the latest firmware update or specific troubleshooting steps I should undertake, I would greatly appreciate your guidance in this matter. Additionally, if there are any firmware patches or updates available that may address this issue, please let me know.
Thank you for your attention to this matter. I look forward to your prompt response and assistance in resolving the AI tracking issue.
@Ronny_Singh@Omnilert
Would you mind working with our engineer in the same WhatsApp group and work the matter out, please?
SIYI General Inquiry: +86 188 2021 4087
My name is Sid, and I’ve been encountering some difficulties with my Herelink v1.1 system while trying to connect it with a Siyi camera for my drone. Initially, when I connected the camera with the Here-Air unit (ETH), everything worked smoothly. However, after a few days, the connection ceased to function.
I’ve tried troubleshooting the issue myself, but haven’t had any luck so far. Could you please assist me in figuring out how to successfully stream video through Herelink with the Siyi camera using the ETH connection? Additionally, I’ve found that everything works perfectly fine when using the HM30 module. I also have your Mosaic Camera Module, including A8, ZT6, and ZR30, all of which function excellently with the HM30 module. However, when I attempt to use them with Herelink, they stop working after a few days.
Your guidance in resolving these issues would be greatly appreciated. @SIYI
