SIYI ZT6 Mini Dual-Sensor Optical Pod (Gimbal Camera) - 4K Optical Camera, 640 x 512 Thermal Imaging
Most probably the issue in this case would be different gateways for herelink and SIYI camera. Try changing the IP and gateway of the camera to the same group as herelink is, or vice versa.
Hi! I cannot apply telemetry via the Minim OSD menu to the zt6 camera via CVBS! Tell me, maybe there are features that are not mentioned anywhere?
Thermal imaging is not activated is the error I am getting on mk15 for thermal video output
You will need to activate it
Please write to support@siyi.biz and the team will guide you
Hi so initially the video was coming without the thermal and all of a sudden the camera started blinking red red amber
Attaching video links please have a look and advise , we are unable to update the firmware for camera
@SIYI
https://drive.google.com/drive/folders/1-UorjGzYViMAklF73HegOv2Co3FnPWor
I think it is just a failure in firmware upgrade
Please format the SD card to FAT32 or use another card
If it still didn’t work, let’s continue with the support email
Hi @SIYI
We have used 6 different cards and formatted them as stated.
Everytime we put the card in the camera for update it doesn’t happen and when we take out the card and insert in laptop the bin file gets deleted from the card.
Also when the camera is connect to siyi assistant only gimbal firmware is visible .
Also how do we activate the thermal video mode? Initially the camera video was visible without the thermal but since the red red amber light coming no video.
Please help us stuck with it since 10 days now
Introducing ZT6 Mini Dual Sensor Optical Pod
Where i can download old version of firmware?
Thermal camera just shows gray screen. Or it’s defective?
I have 2x ZT6
1 - Camera works, thermal displays just gray empty stream
2 - Camera has corrupted image, thermal works
Tried to exchange thermal module, both works (also tried to connect to DJI Mavic, they works)
Is there any way to make work at least one or any RMA or is there any way to send it to factory for repair?
Gimbal Camera 1 only displays gray, which may be due to the camera lens not being activated. Please visit the following link to obtain SIYI Assistant v1.4.0 software, and activate it within the software after installation. Before installing the software, please uninstall the installed SIYI Assistant software and clear the uninstallation residue on the installation path.
Link: SIYI Assistant - Google Drive
Hi, is there any way to downgrade the video output from the zt6 camera. My camera is currently giving 1080p video, i want to change it to maybe 720p. Is it possible? And how?
You can reduce the camera’s pull resolution through SIYI FPV software, UniGCS software, or SIYI Assistant software. Currently, there are two specifications that can be adjusted: 720p or 1080p. For specific connection and debugging methods, please refer to the user manual.
Manual download link: https://siyi.biz/siyi_file/ZT6/ZT6%20User%20Manual%20v1.1.pdf
Hi, I’ve tried using SIYI FPV and SIYI Assistant softwares, however can’t change the resolution. Neither could find the steps to do so in manual. Can you guide on how to change the resolution step by step.
Bundle of thanks
Please refer to it.
Dear SIyi Team,
I’m using a ZT6 camera with an MK15 RC on the drone, and while streaming in the QGC while flying, I’m getting a lot of Frame drops, and the video is not clear. How can we resolve this? I have updated all the firmware as per the instructions, but the issue still remains unresolved..
thank you
What version of QGC are you using? Please use the SIYI FPV software that comes with MK15 to check if the streaming screen is working properly. Please also check the encoding format of the camera. You can try modifying the encoding format in SIYI Assistant.
