I am currently using the SİYİ ZT30 camera, which provides both thermal and RGB imaging. I regularly follow the firmware updates for this camera. However, with the current firmware downloaded from the official website, I am experiencing issues in changing the color palette in thermal imaging mode. When I change this setting and save it through the Siyi Assistant app, I observe no alterations.
I download the firmware files from https://siyi.biz/en/index.php?id=downloads&asd=602. Currently, I am using the ‘Iron Oxide’ color palette in thermal imaging and wish to change it to ‘White Hot’. Could you please assist me with this issue?
I have downloaded the latest firmware pack from the Siyi website at this link. However, after setting the Thermal imaging pseudo color and saving the settings, when I reconnect to the system, the color palette section appears empty.
Then, I connected the camera to the power source without any USB connection and waited for 3-5 minutes, expecting the camera to automatically update its firmware. However, after the waiting period, I turned off the camera, removed the SD card, and then powered it on again to check the firmware version via USB, only to discover that no update had taken place. Moreover, when I checked the SD card, I found that the “.bin” file had been deleted and new folders were created. I repeated this process several times but ended up with the same result each time. Could I be missing a step somewhere?
It appears the issue was related to the model of the SD card I was using. Although two different SD cards were recognized as FAT32, the update could not be completed with them. However, when I tried with a SanDisk card, the update was successfully performed.
In addition, I am curious to know if there is software support within the camera that allows synchronized output from both RGB and thermal cameras simultaneously. Also, is it possible to retrieve temperature data for the entire image from the thermal camera? In other words, can I extract temperature data for every pixel point?
@SIYI Is it possible to use the ZT30 with a Herelink or is the SIYI remote control a prerequisite for the full range of functions? And if it is possible, what are the limitations?
I was trying the ‘Request Temperature from the Thermal Imaging Camera Once’ function with the new update, and bin files came into the SD card. Do I need to read these? How can I do it with Python? Also, do I have a chance to pull this information via Ethernet?
Hi, we setup the Control SIYI Optical Pod (Gimbal Camera) in SIYI FPV App through SIYI link. As soon as I plug in the power, we encounter a spin problem in yaw rotation. The camera starts to rotate rapidly and we cannot see the image in the FPV app. When I look for FW update, I can see and update the Gimbal module, but the Zoom module does not appear at all, the camera FW also does not appear and it does not update from the SD card.
Please write to support@siyi.biz or contact your sales representative directly
It’s not timely and effective to do trouble shooting and offer solution for very complicated issues.
