SIYI UniRC (More Frequencies, More Bandwidth, More Channels, More Open, More Advanced)
@SIYI what voltage does the air unit accept?
I looked in the manual and can’t seem to find it.
2S to 18S direct input
I have the unirc 7pro and I have my copter connected to unigcs, The screen is white with no maps. How do I get the maps to show? Yes I have a gps connected,
Hello!
The first step is to connect your UniRC 7 to the Internet to obtain data.
Step two, open UniGCS. Click on the black circular paper airplane icon in the bottom left corner of UniGCS to bring up the map.
Step three, click on the map mini window to switch to full screen display.
I tried all those, but it says UNIGCS wont run without google play services which are not supported on your device.
I have the R1M camera and I got it to display in unigcs but not in qground control, I read through the manual a few times and can’t seem to get it working. I am running the most up to date version on QGC.
I got the camera working, took me a bit but figured it out.
Still no maps in unigcs.
@SIYI
Any help?
Hello! We are intensifying the development of firmware for the UniRC 7 series to adapt to Google services. It will be updated in the next version. Please be patient and wait.
Please follow the steps below to set up QGC:
Select Tool → Application Settings → General → Fly View → Video Settings → Source → RTSP Video Stream → RTSP URL → rtsp://192.168.144.25:8554/main.264
Uni7pro
I was flying yesterday with the uni7pro and it just disconnected from the quad it was on and triggered RTL. Thankfully I had it configured correctly for RTL. Is there some way I can look at error logs in the controller to figure out what happened? The quad was only about 75ft away from me when it happened.
The battery was fully charged, antennas all in the correct position and the controller was setup for dual frequency.
This is the only time that it has happened but now I’m a little anxious about flying
Hi @prsh8ya Tanner
I totally get where you’re coming from.
But I really think it’s crucial to figure out and proof what caused this RTL, due to the outcome will decide if SIYI should take the UNIRC off the market until they’ve found the issue or if you should fix your problem before the next flight.
I’m sorry to ask, but what makes you so sure that the connection failure is due to the UniRC connection and not, for example, an accidentally activated RTL switch or a loose cable?
It would be really helpful if we could get a log file showing whether the SBUS flag of the SIYI airunit or something else triggered this RTL.
Rolf
I’m sure the unit lost connection because the video feed froze, the telemetry froze.
That makes sense. I’m curious to see what @SIYI thinks.
@SIYI
What is the Radio Frequency Field Strength/Power for 2.4GHz and 5.8 GHz in mW EIRP or mW ERP for UniRC 7 Pro?
I cannot find the answer in the UniRC 7 Series User Manual.
@SIYI here is the bin file that shows the rtl triggered after the remote froze.
Hello! Sorry for any inconvenience caused to your use. I checked the logs and found that the flight process did not last long. Is this UniRC 7 on its first flight mission? Has there been any unstable signal during previous use. I would like to know how much power is supplied to your Air Unit.
Could you please enable the remote control log to record the status of the remote control during flight? Would it be convenient for you to operate it?
The flight didn’t last long because the remote screen froze which triggered a RTL. I have 12 volts to the air unit.
How do I enable remote logging?
I currently do feel confortable with this system.
Also @Jai.GAY asked and I would like to know also… What is the Radio Frequency Field Strength/Power for 2.4GHz and 5.8 GHz in mW EIRP or mW ERP for UniRC 7 Pro?
I have also request to Siyi support to look into having the followings features:
  1. Remember the button last state before power off and re-powering back
  2. UniGCS, to remember the last user interface (map or camera view) selected before app shutdown/closed and relaunch.
  3. Those buttons with LED to show light when configure for NON flight mode usage to be lit.
  1. I will communicate with our development engineers about the requirements for keeping records of the button status and UniGCS interface during shutdown, and they will evaluate whether they will be added in future versions;
  2. Does the non flight mode switch refer to the M1 to M6 switches? All switches will light up blue by default, and switches M1 to M6 will light up blue when the mapped channel value is 1950.
Yes, when configure for 3-gears, M4,5,6 for other usage it will not light up. I have communicated with Siyi Yang phone number ending with 3253. He/She understands what I mean.
On another note, L1,2, R1,2,3 should have LED embedded underneath, unfortunately they are not for the price.
Is it in EIRP unit? 26.9 dBm?
