SIYI UniRC (More Frequencies, More Bandwidth, More Channels, More Open, More Advanced)
Four years of hard work, the sword is at its peak when it is unsheathed!
Dear Community,
We are proud to announce that a brand new SIYI RC series are coming in schedule! Stay tuned and welcome to share your opinions!
SIYI UniRC 7 PRE-RELEASE!
SIYI UniRC 7 & 7 Pro
New Era Handheld Ground Station
UniRC 7 / 7 Pro is accepting pre-orders!
Order now by writing to store@reebot.com !
UniRC 7 / 7 Pro new era handheld ground station is specially designed for smart robots such as drones, cars, and boats. It integrates 2.4/5 GHz dual-band, 40 KM communication distance, 4K@30fps decoding performance, transmission bit rate up to 65 Mbps, AES encryption, 1600-nit 1080p resolution high-brightness 7-inch touch screen, unique sub joystick design, six flight mode buttons and quick-release belly bracket and many other carefully polished highlights and innovative designs, providing the ultimate experience for the smart robotic ecosystem and leading the industry’s product standards to a new level.
https://siyi.biz/en/index.php?id=759
@SIYI If I buy this unit can I purchase multiple air units for all my drones, will there be an issue with having multiple air units bound?
If so what unit do I purchase and where would I find it?
Thanks for your attention to the SIYI new RC
UniRC 7 series support binding to max 5 air units in turns and saves binding for easy switching, but there should always be only one air unit binding with the ground unit. Same as MK15 or MK32
UniRC 7 Pro Range Test (Ground to Ground)
3+ km achieved with stock antennas!
UniRC 7 Tutorial Vol.1 - First Use
UniRC 7 Tutorial Vol.2 - Interface & Indicators
UniRC 7 Tutorial Vol. 3 - First Use with UniGCS
UniRC 7 Tutorial Vol. 4 - Bind
I just ordered one of the unirc 7 pro. Can I use mission planner with it?
@SIYI
I purchased the 7 pro, do I have to have this to hook a camera to the air unit? Does it come with the 7 pro?
UniRC 7 Series Handheld Ground Station User Manual 4.2.2 Mission Planner
1.4 List of items
What cameras do you have on hands?
IP cameras can connect to UniRC 7 series easily
or you can pick up some basic cameras here
I have a gopro type camera that has a mini hdmi out and I was wanting to use it.
I see
Then you need the HDMI input converter
I am currently using a Unirc 7 Pro device and would like to install Google Play Services on it. However, I am unsure of the steps to achieve this.
Could you kindly guide me through the process or provide reference materials, such as pictures, a step-by-step guide, or relevant links to help me complete the installation?
please support @SIYI
You may want to first find out the chipset type and get the correct APK package or do the right process.
On second thought, why do you need Google Play Services?
