Hi Frank,
Yes, that’s the version of QGC I’m using. Please see attached picture for the area that I’m attempting the configuration.
Matt
Hi Frank,
Matt
What are your settings here in General?
The settings are default as I need to be able to switch between the USB camera that is connected to the Navigator board and the SIYI Camera.
I’m not familiar with your USB camera but I believe you need to input SIYI gimbal RTSP addresses here for video stream and control
Hi Frank,
Ok I did that and I now have control over the camera gimbal, but no video feed. Also the three fields (Source, RTSP URL & Aspect Ratio) no longer appear under video settings so I can’t modify to see if I can get the video feed going. Please see image.
Any idea how I get access to those settings again? I’d rather not do a fresh install of QGC if possible.
Regards
Matt
Hi Frank,
It works! I had to disconnect the USB camera first, but the SIYI camera now works.
Thanks
Matt
Frank,
Just one more thing… The basic camera controls that are standard with standard QGC are working and saving both video and pictures to the windows PC running CGC, but the custom start/stop video and take photo buttons that SIYI have added don’t save video or photos on the windows PC or on the SD card on the camera. When does the SD card get utilized for the storage of video and photos?
Cheers
Matt
What recording button you are using? The QGC original one or the SIYI added UI?
I tryed both sets of buttons. The standrd QGC buttons write files to the PC ok, but the new buttons dont write files to either the PC or the SD card. So it looks like the SD card doesn’t get used at all.
Agreed the image you have there is much better
@SIYI Hi, i am using the ZT6 camera and SiYiQGroundControl in github https://github.com/x-tools-author/siyiqgroundcontrol/tree/master
. I want to use the temperature feature of the camera such as: take point temp, box temp and max, min temperature of the image,… but the source code doesn’t have. You can add some feature about temperature of the camera in the siyiQGroundControl source in github?
@SIYI Hello, I am trying to setup the ZT6 camera with SIYI QGC and the Herelink v1.1 Controller, but I am having issues with the video feed. I was able to get the camera feed visible in the SIYI FPV app, but it does not show in SIYI QGC. I am able to get QGC connected to my vehicle and I have inputted the correct rtsp address from the ZT6 manual (and tried all of the listed ones), but it just says “WAITING FOR VIDEO” and the console log has the pictured errors. Any insight into what could be causing this issue or should I try consulting the Herelink forums?
Please also show us the exact RTSP addresses you’ve input in QGC
Here is all of that info. Gimbal firmware is version 0.1.9, camera firmware is 0.1.3, and the SIYI QGC version is 4.2.3 which I downloaded from the website. The RTSP address I am using is 192.168.144.25:8554/video1
The address in QGC’s RTSP URL is: rtsp://192.168.144.25:8554/video1
You have not added rtsp://
I have fixed the rtsp address but the issue still remains.
I have solved the issue. I needed to change the code format in SIYI PC Assistant from H265 to H264.
