SIYI A8 mini over Ethernet without Airunit
Hello everyone!
I’m starting this thread to explore the possibility of using the SIYI A8 mini camera connected via Ethernet to a Raspberry Pi, and streaming video using 4G internet. This approach could potentially extend the transmission range and offer a more cost-effective solution, as it wouldn’t require purchasing an Airunit like the HM30. I’ve searched but haven’t found any similar projects or information about someone successfully connecting the SIYI A8 or ZR10 solely via Ethernet. Please share your thoughts and experiences.
It is completely possible, since all you need on the camera side is to receive RTSP stream and send it further through LTE.
I’m just not sure it’s going be a cost-effective solution, since HM30 is quite cheap (under $300 for a set) and for LTE link you gonna need a Raspberry PI ($50), a decent LTE modem (another $50), some hardware on the ground side with LTE capabilities etc.
Anyways, feel free to check my free software which is already working over LTE: SokilLink Cloud: Plug-and-play drone control and video streaming over LTE
It doesn’t support SIYI cameras yet, but an A8 Mini is already laying on my shelf for a couple of months so I’m going to add support for it eventually.
Hello everyone!
Could you please share if it was possible to connect the siyi camera to the raspberry pi? I am trying to connect a similar camera from this brand to a companion computer but i wasn’t sucessful on getting an RTSP stream working. The idea is to process images from the camera on the companion computer. But i wasn’t able to even read the stream. Through the “ethernet port” or RJ45 port.
Yes, it’s completely possible, it was working for me.
Make sure to pick right codec at first at Siyi Assistant app.
Hello! An extremely necessary instruction, I beg you! I haven’t slept for three days now, trying to figure it out…
come over that github issue ,we are getting closer to solve this problem , a guy said some SIYI NEW RJ45 cables are broken maybe this is also your problem
