This is the video guide for firmware upgrade
I am currently trying to stream 1080p through the ethernet port, however every time I try and set âUltraHDâ stream resolution in the PC assistant app, it reverts back to only âHDâ. I have tested and it is definitely only streaming at 720p. How can I make it stream at 1080p over ethernet?
A8 mini does not switch stream resolution at this moment
Thank you for your quick response, do you know when this will be available? Iâm currently doing a computer vision project and 1080p streaming would be very helpful.
Hallo Frank, thanks for your work and for new firmware to try.
I tried to flash 30fps firmware and there was some issue with new 64GB SD card, but old 8GB fat32 SD card works fine and firmware was updated correctly (SIYI assistant shows 0.1.8). But I can still see an issue with picture broken if using with CSI adapter. As first I tried on 2 different monitors (10" full HD display and 22" PC monitor) to see HDMI info. picture was correct on both, but it show 1080p/60hz (not 30)
Just to compare, this is how image looks on firmware v 0.1.6 on OpenHD and CSI adapter:
And with FW 0.1.8 is a bit better, but still messed up:
Also tried with RUBY FPV, same as OpenHD:
so seems like thereâs still no 30fps in last FW version, or maybe some different issue.
Thanks for the feedback.
Can you tell us a little more about the CSI adapter, please?
- Is it a must for your network?
- How does it look?
- Which part do you put it in your network?
CSI adapter has to be use to convert HDMI signal to CSI2 signal on raspberry pi (used for transmit video via wifi). Most of the CSI interface support only 30p framerate.
this is exapmle of CSI interface Iâm using:
https://s.click.aliexpress.com/e/_DEkRIal
and this is how the video transmitting system is connected (OpenHD or RUBYFPV):
Hi All,
I can control gimbal from AP.
But can not find FPV mode. I have only Lock and Follow.
How can i switch FPV mode?
Thanks.
I have AP 4.4.0dev
Gimbal 0.1.8
Camera 0.1.8
Hi @FPV_Glider,
AP doesnât allow setting the mode to FPV. Just âlockâ and âfollowâ. Now, I must admit that it is like this because I didnât understand the difference between âFPVâ and âfollowâ. I guess in FPV mode the gimbalâs yaw moves very closely with the heading of the vehicle? while in âfollowâ mode the gimbalâs yaw is slightly âlooseâ so if the vehicle yaws quickly the gimbal will lag slightly?
If people say we need this then I think we can add support. Currently the âMount Lockâ auxiliary switch position controls are low:follow, middle:follow, high:lock. Perhaps we could make either the middle or low position set the the gimbal to FPV mode?
Sorry for the slow response.
Re the issue you saw with turning on/off recording. I think the issue may be related to timing. The gimbal interface doesnât allow AP to directly turn on/off the video recording, instead it only allows âtogglingâ so the AP driver can potentially become out-of-sync with the gimbals actual recording state. The driver does request the gimbalâs recording state regularly though so I think this can only happen if the user triggers recording on and then off within 1sec.
Does this fit with what youâre seeing?
Hi!
Thanks for reply. I need FPV mode because it can track up and down and it respond to change of the heading much faster. In Follow mode camera is always horizontal and if the plane goes up or down camera is looking the wrong way.
Could you please implement FPV mode in future verstion. It will be very helpful for planes and gliders.
Thanks a lot.
It would be good to have FPV mode in low (to have it by default). FOLLOW - middle, LOCK - high.
Thanks.
We had some debate on OpenHD discord regarding CSI converters. Despite the fact that Toshiba 358743G (processor and baseband chip on most CSI converters) datasheet support 1080p60, seems like Raspberry Pi itself cannot handle more than 1080p25 or 720p49 So I would like to ask you, if it is possible to implement one of the two mentioned resolution/framerate for HDMI out in new firmware, so we can try in, or even try to make it configurable somehow. Thank you.
Hi Randy,
Fpv also means that roll follows frame, thus slight or none stabilization. Same goes for tilt, but you still can control the angle
@Dimitris_Stefanakis, @FPV_Glider
Thanks very much for that explanation of FPV mode. So the gimbal moves in body-frame rather than earth-frame. Iâve added an issue so we donât forget about this enhancement request.
I canât immediately promise when we will implement this but I hope it wonât be too far in the future. We are actively working on improving APâs gimbal and camera support but thereâs still a lot of items on the list!
Siyi a8 mini ethernet port configuration.In Manual it only for hdmi.
Hi @rmackay9. Apologies for this question, the answer seems obvious to me but I want to check a box and make sure I am reading the comments in this thread correctly before figuring out my next steps.We have a Foxtech VTOL plane running Arduplane V4.1.0dev (fcde1e73) with some custom parameters from FoxTech. What I see here is that the gimbal controls nor camera controls would not work on our VTOL unless we were willing to update to 4.3.3. Is this correct?
Thanks again,
Adam
Yes, thatâs right. The SIYI gimbal support was first added in AP 4.3.1 so the autopilot needs to be running this version or higherâŚ
