Hello.
I run SITL by following method :
https://ardupilot.org/dev/docs/building-setup-linux.html#building-setup-linux
clone ardupilot folder on window WSL ubuntu, and ran below command :
drone@XXXXX-XXXXX:~/ardupilot/Rover$ sim_vehicle.py Rover -A “–serial0=udpclient:127.0.0.1:14551” --no-mavproxy --custom-location=“-2.35970,-173.7070,0,0”
drone@XXXXX-XXXXX:~/ardupilot/ArduPlane$ sim_vehicle.py quadplane -A “–serial0=udpclient:127.0.0.1:14550” --no-mavproxy --custom-location=“-2.35970,-173.7070,0,0”
it seems to run well,
but when I use joystick, it does not respond.
it is not my setting fault because in manual mode or fixed wing mode I can control the airplane. and I used joystick with actual aircraft many times. it is not the setting fault of me.
only in quadplane mode, it does not respond to joystick.
