Novice question here. Is there a way to access the iris SITL drone’s battery level? I’ve tried the bat
command in mavproxy:
MAV> bat
STABILIZE> STABILIZE> No battery information
as well as trying to view the /battery
ros2 topic:
jamison@jamison:~$ ros2 topic info /battery
Type: sensor_msgs/msg/BatteryState
Publisher count: 1
Subscription count: 0
jamison@jamison:~$ ros2 topic echo /battery
but nothing is happening when echoing.
Do I have create my own subscriber?
I’m running Gazebo Harmonic and Ros2 Humble.
Thank you!
rhys
(Rhys Mainwaring)
2
The battery topic for ArduPilot via DDS is
/ap/battery
For a list of all topics see:
% ros2 node info /ardupilot_dds
/ardupilot_dds
Subscribers:
/ap/cmd_gps_pose: ardupilot_msgs/msg/GlobalPosition
/ap/cmd_vel: geometry_msgs/msg/TwistStamped
/ap/joy: sensor_msgs/msg/Joy
/ap/tf: tf2_msgs/msg/TFMessage
Publishers:
/ap/airspeed: geometry_msgs/msg/Vector3Stamped
/ap/battery: sensor_msgs/msg/BatteryState
/ap/clock: rosgraph_msgs/msg/Clock
/ap/geopose/filtered: geographic_msgs/msg/GeoPoseStamped
/ap/gps_global_origin/filtered: geographic_msgs/msg/GeoPointStamped
/ap/imu/experimental/data: sensor_msgs/msg/Imu
/ap/navsat/navsat0: sensor_msgs/msg/NavSatFix
/ap/pose/filtered: geometry_msgs/msg/PoseStamped
/ap/tf_static: tf2_msgs/msg/TFMessage
/ap/time: builtin_interfaces/msg/Time
/ap/twist/filtered: geometry_msgs/msg/TwistStamped
Service Servers:
/ap/arm_motors: ardupilot_msgs/srv/ArmMotors
/ap/mode_switch: ardupilot_msgs/srv/ModeSwitch
Service Clients:
Action Servers:
Action Clients:
