@ujjwalrathod007 if the command is not found when run from /ArduPlane folder, you likely don’t have the python path setup correctly. alternatively you can run ./sim_vehicle.py from /Tools/autotest, in this case you’ll need to add an argument to specify which vehicle to build though.
