When I run:
git submodule update --init --recursive.
I got:
error: pathspec ‘–-recursive’ did not match any file(s) known to git.
When I run:
./waf configure –-board CubeBlack
I got:
No function ‘\xe2\x80\x93-board’ defined in /home/mpbatista/pitangus/wscript
I’m working in a forked version, but it is an issue even when I clone the master one.
are you running the commands inside the ardupilot directory?
Yes, I am running inside the clonned directory. I’m working in a WSL enviroment into ubuntu installed in Windows.
Could you please provide the entire terminal output as an image or text?
mpbatista@ENG-MARCOSBATISTA:~/pitangus$ git submodule update --init –-recursive error: pathspec ‘–-recursive’ did not match any file(s) known to git.
mpbatista@ENG-MARCOSBATISTA:~/pitangus$ ./waf configure –-board CubeBlack Setting top to : /home/mpbatista/pitangus Setting out to : /home/mpbatista/pitangus/build Autoconfiguration : enabled Setting board to : sitl Using toolchain : native Checking for ‘g++’ (C++ compiler) : /usr/bin/g++ Checking for ‘gcc’ (C compiler) : /usr/bin/gcc Checking for c flags ‘-MMD’ : yes Checking for cxx flags ‘-MMD’ : yes Checking for need to link with librt : not necessary Checking for feenableexcept : yes Checking for HAVE_CMATH_ISFINITE : yes Checking for HAVE_CMATH_ISINF : yes Checking for HAVE_CMATH_ISNAN : yes Checking for NEED_CMATH_ISFINITE_STD_NAMESPACE : yes Checking for NEED_CMATH_ISINF_STD_NAMESPACE : yes Checking for NEED_CMATH_ISNAN_STD_NAMESPACE : yes Checking for header endian.h : yes Checking for header byteswap.h : yes Checking for HAVE_MEMRCHR : yes Checking for program ‘python’ : /usr/bin/python Checking for python version >= 2.7.0 : 2.7.17 Checking for program ‘python’ : /usr/bin/python Checking for python version >= 2.7.0 : 2.7.17 Source is git repository : yes Update submodules : yes Checking for program ‘git’ : /usr/bin/git Checking for program ‘size’ : /usr/bin/size Benchmarks : disabled Unit tests : enabled Scripting : enabled Scripting runtime checks : enabled Checking for program ‘rsync’ : /usr/bin/rsync ‘configure’ finished successfully (2.323s) No function ‘\xe2\x80\x93-board’ defined in /home/mpbatista/pitangus/wscript
I think something is wrong with the - s.
Does the above work?
Also, do
./waf configure --board CubeBlack
You have a mismatch at “–” and “-”
Oh thanks so much! You really helped su much. I still have a problem with submodules. Related to configure, I got it and now I’m able to upload in pix. I run and I got it:
mpbatista@ENG-MARCOSBATISTA:~/pitangus$ git submodule update --init --recursive fatal: No url found for submodule path ‘modules/PX4Firmware’ in .gitmodules
In my .gitmodules I have:
[submodule “modules/uavcan”]
path = modules/uavcan
url = git://github.com/ArduPilot/uavcan.git
[submodule “modules/waf”]
path = modules/waf
url = git://github.com/ArduPilot/waf.git
[submodule “modules/gbenchmark”]
path = modules/gbenchmark
url = git://github.com/google/benchmark.git
[submodule “modules/mavlink”]
path = modules/mavlink
url = git://github.com/ArduPilot/mavlink
[submodule “gtest”]
path = modules/gtest
url = git://github.com/ArduPilot/googletest
[submodule “modules/ChibiOS”]
path = modules/ChibiOS
url = git://github.com/ArduPilot/ChibiOS.git
[submodule “modules/libcanard”]
path = modules/libcanard
url = git://github.com/ArduPilot/libcanard.git
Did you run git submodule update --init --recursive
command inside the ardupilot repository folder?
Do cd ardupilot/
before executing the git submodule update --init --recursive
Above is valid for building ardupilot main repository from source code since I don’t know which forked repository you are using.
