Hey, guys. running a px4 radiolink module and couple issues. One, i hooked up my esc to channel 3 but i don’t get any values when going through servo output. I do. however get throttle values in radio calibration. But when going through esc calibration, it says set param error, Please ensure your version is AC3.3+. PLEASE HELP very frustrating.
Update to the latest stable ArduPlane and make sure your vehicle is armed, otherwise no PWM output.
I am having the same problem. There is one thing I don’t understand it is a plane firmware flashed, why it needs to be arducopter.
- Uninstall mission planner.
- Install the latest missionplanner
- Update the firmware to ArduPlane 4.0.9
Thank you for your quick reply.
1, The mission planner I just downloaded few days ago. I guess it’s the latest version.
2, I am flying a traditional airplane. What is the reason that I need to update the firmware to arducopter.
Additionally, I am using the latest version of the fiware because I need to use the Fport.
sorry I did not read carefully, I thought you mean Arducopter.
Is it 1.3.74 mission planner? - Update the firmware to ArduPlane 4.0.9
would this version support Fport?
- yes.
- No. You need 4.1.0-dev for that.
2, this is the version that i am using.
3, i set the esc with Dshot600, it tells that needs to be AC3.3+, what did i set wrong?
can i set 2 esc with dshot while other servos all remain pwm 50HZ. firmware 4.1.0 latest
hi, you got lucky with the problem
