I’m about to order servos for my 450L and wanted to see if KST DS315MG for cyclic and DS565X for tail were good choices in your opinions.
I’ve read some discussions such as this about running 760us servos. Is there a disadvantage to running a narrow band servo with ArduCopter?
Also, coming from FBL, there is a lot of information out there on Helifreak, etc., about setting operating frequencies to match servo specs in order to prevent damage.
I believe that ArduCopter defaults to 400hz for SERVO_RATE.
Should this be lowered to prevent damage? What would be the preferred setting for this parameter? Stay below the lowest frequency spec for all of the servos (333hz in the case of the DS315MG’s)?
Thanks for any help!
