I can’t control my tail servo by the remot control,because it’s a 760us servo. Do I have to use gyro instead of flight control?
@Allens You can still control it. You have to set the SERVOX_MIN and SERVOX_MAX to the appropriate values for that servo. You will want to be conservative initially to be sure you don’t bind any linkages. So set the MIN for 500 and the max for 900. Then you will set the SERVOX_TRIM for 760. You can then increase/decrease the max/min to get the desired travel range.
