Radiolink PIXHAWK 2.4.8
Copter 4.5.3
FMUv3
FlySky FS-i6s 10 channel ppm
Servo connected to AUX 1
I am currentrly trying to access a servo for a servo metal claw which i want to access it from channel 8 , i tried servo9 function RC8in, Landing gear, gripper , camera gimble but coudn’t able to move servo
what should i do? please help!
Regards
Kaustubh Shriyam Dubey
You need to add a 5v supply for the servo rail.
I am providing 5v from ESC, should i provide it separately??
I tried supplying 5v from my laptop no progress
dkemxr
(Dave)
June 6, 2024, 5:59pm
5
This is all you have to do assuming you set up the Transmitter mix correctly and the Aux outputs are configured for PWM which is default.
It shoing gripper load message when i use channel 8 switch on my Fly Sky i6S but the motor is not moving what should i do?
pix_param.param (20.1 KB)
this is my parametter file
dkemxr
(Dave)
June 7, 2024, 11:37am
8
You have GPIO configured for all Aux outputs. See that message that says RCOut:None?
Servo9 = Gripper
Servo10= RC7in
Issue now got solved and i removed servo9 from bitmask and add gripper parametera
Thank You so much for the help
Regards
