For a VTOL project I would need to add PWM ports to a Kakute F7 AIO board.
A while ago I made a firmware for Arduino Mini based on the AP_RC library.
It uses a home made protocol and the HDLC transport layer.
I was quite happy with this expansion board and today I could reuse it as it is.
But then I would have to add my protocol and library to ArduPilot, and I suspect the effort would be a waste of time.
I once used the Pololu serial to PWM boards but I don’t have them at hand now, and I am not aware of any use case with Ardupilot.
I am now leaning toward making a firmware which uses the MAVLink protocol to request the MAV_DATA_STREAM_RC_CHANNELS stream.
The board I plan to use is an Arduino Pro Mini
Are there any similar and adopted project, namely using serial ports to expand the PWM ports on an autopilot HW, and ideally using an arduino board and MAVLink ?
Any suggestion about I could add PWM ports to a limited HW ?
This is awesome and exactly what I needed.
Actually I would need only one extra servo on the Kakute so I could use the LED Pin as is.
Thanks for your work and suggestion !
As for the Sbus decoder, package delivery is a bit tricky these days.
Maybe in the future I could make a firmware that use MAVLink to output PWM on an arduino.
But for now I will stay focused on the existing pile of projects.
