From what I have read it would seem that since 3.5.4 we can now connect serial devices to the SERIAL 5 port, which would seem to be the 3 pin console header (labelled CONS) on a standard carrier board (which is great as I have used all of the others up!).
I am thinking of connecting up my micasense rededge to this port in order to give it GPS and heading data but I can’t seem to find the pin layout for this three pin connector (this http://www.hex.aero/wp-content/uploads/2016/07/DRS_Pixhawk-2-17th-march-2016.pdf mentions it but does not go into the specifics of the pin layour as far as I can see) … could someone could point me in the correct direction so I don’t plug things in the wrong way and end up stuffing an expensive sensor
I will letyou know once I try it, probably wont be for a little while though as leaving it in its current configuration for now until I get my Emlid Reach module (will then need the space for extra gps antenna).
