Send rate for sending cmd_vel or SET_POSITION_TARGET_LOCAL_NED
Hii all.
I am using mavros to send cmd_vel or SET_POSITION_TARGET_LOCAL_NED to the drone. What is the correct send rate in Hz do I need to send these commands to the drone?
Thank in advance.
Arducopter 4.0.5
Mavros latest
Jetson tx2
Mode GUIDED has had many, many improvements in ArduCopter 4.1.3. Anything between 5 and 10Hz should be fine
Hi thanks for the tip.
What kind of changes? I read the release notes. Did see anything specific.
For the details you will have to dig in the git log for PR`s from lthall.
