a practical question has just immerged I have a s500 quad running the great apm2.8 actually it was the first quad I ever built, still impressive though aged 5 years. I decided to build a new one using the pixhawk this time , I already buyed one and flashed it just to check if its working… I was opening the mission planner I use the mission planner 2.0 by micheal obams it gave me an update note! I updated on one of the two laptops I have but kept the other older version of mission planner 2.0 on the other and even an older mission planner 1.8 I feel I may need all, but I intend to use telemetry in this build.so I cannot get away with this two laptops thing… my question is what if I put three versions of mission planner on same laptop, any troubles may occur ???
no replies
You only need one version of Mission Planner. The latest version. Some menu’s will not work but you can always use the Full parameter list. I was just using the latest version of Misison Planner to connect to an obsolete APM FC via telemetry.
