(I’m developing on Windows 10 with Cygwin)
I’m currently testing a new feature on a library. Test of ArduPlane had no problems, but test of ArduCopter runs (near the end of the test?) in an error, that seems to me to be a problem of the test-environment.
It tells me, that the command “gpsbabel” is not known and the module “cv2” is not existing.
autotest-Fehler.txt (3.2 KB)
I tried to download and compile gpsbabel, but there are problems because Qt>=5.9 is necessary. To install that, I run in further problems (based on python2.7?):
“$ pip2 install qtbase5-dev
DEPRECATION: Python 2.7 reached the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 is no longer maintained. A future version of pip will drop support for Python 2.7. More details about Python 2 support in pip, can be found at https://pip.pypa.io/en/latest/development/release-process/#python-2-support
ERROR: Could not find a version that satisfies the requirement qtbase5-dev (from versions: none)
ERROR: No matching distribution found for qtbase5-dev”
And the cv2 module I can’t find anywhere.
I think about an installation from scratch. So I looked for an updated instalation-guide for the development-environment, but the script is still using python2.7 !?
So I nearly despair of that problems, because my contributed feature seems to run perfectly, but I’m not able to autotest it.
So what can I do to fix that problems?
Btw: If thats the wrong threat, pls give me a hint where to start that.
