RTL to a pre-determined location
I understand that RTL returns the drone to where it was armed. Is it possible to change this to a different location? If I’ll send the Mavlink message “SET_HOME_POSITION”, will arming override it? is it possible to set home using this Mavlink message after arming?
Thanks!
You can always use a LAND command instead of RTL. Having flown many one-way missions I tend to use LAND for most missions now anyway.
Are you asking about rally points?
http://ardupilot.org/copter/docs/common-rally-points.html?highlight=rally%20point
@Montville
Yes! this is what I was missing.
Thanks!
