RTK GPS guided precision landing
Hi
I am trying precision landing. I tested IR-LOCK, which works great. The problem is I need to land on a plate of metal. Something like this
When in high noon, sun will create a very bright reflective light. Such strong light make pixy camera “blind”, cannot detect irlock and lose landing target. And I cannot paint the metal pate to black
So I try other way. I hear some people mention RTK GPS is very accurate. I use two emlid reach RTK module, one for base station, another installed on copter. I take copter off from the metal plate, fly away and switch to RTL mode. But RTL landing is not precision enough even in RTK fixed. I set WPNAV_RADIUS to 20cm and copter hove over home position trying to reach waypoint.
So I try to feed vector from current position -> home to ardupilot precision landing code, create a virtual beacon. Because RTK GPS is cm-level accurate. This virtual beacon should be able to guide copter during landing. This is my test result
https://youtu.be/mUMjagmdYBU. I take copter off, fly away and switch to Land mode. You can see ardupilot take copter back to exactly where it take off. There is no irlock or camera installed
This is the code I changed https://github.com/chobitsfan/ardupilot/commit/b7bc7c3b1f88a85e9c13557197c70c8dd0234b18
The only problem is if you lost the “Fixed” condition with the RTK Gps and you go in “Float”
yes. this is “plan B”. irlock works well most time.
2017/8/26 下午5:01,“lucamax” noreply@ardupilot.org寫道:
lucamax http://discuss.ardupilot.org/u/lucamax
August 26
you go in “Float”
Nice work and modification .
Did you do a pull request with this ?
No. I am still testing it. I still try to find if there is any guiding mechanism other than vision guided, for auto landing
I found modification to code is not necessary. I only need to set EK2_POSNE_M_NSE to a lower value to make EKF trust GPS position more.
https://discuss.ardupilot.org/t/how-does-arducopter-deal-with-rtk-data/13952
