Hi all, I am trying to configure my RPI 4 with my APM 2.8 via MAVLINK. However I am unable to connect RPI 4 and APM2.8 (telemetry port).
I keep getting the message MAV> Link 1 Down whenever I type in:
$ mavproxy.py --master=/dev/ttyS0
Here are the things I have done:
disabled bluebooth of my RPI 4.
I have check my connection via telemetry port.
Kindly help me figure out what the problem is. I would really appreciate it. I have been stuck for very long and I need help.
I’ve also tried that, but however it is just waiting for heartbeat at Mav> , with no response.
FC have set at 921000 as well. - same response for both ttyAMA0 and ttyS0
Done. But however now, I get this for ttyS0:
pi@raspberrypi:~ $ mavproxy.py --master=/dev/ttyS0 --baudrate 921600
Connect /dev/ttyS0 source_system=255
Failed to connect to /dev/ttyS0 : Could not configure port: (5, ‘Input/output error’)
Well i think we went over everything, you are probably overlooking something, recheck everything from the beginning.
Check you are using the correct pins on the raspberry.
Corrado
Do not use mavproxy with higher baudrates than 115200. It may result in connection problems sometimes.
Also try to use /dev/serial0. The RPi should route the UART connected to the UART pins to that device.
