I upgraded my rover to 4.1.5 - it was on some very old 3.X version before - and it seems like the functionality of my start/stop switch for auto movement has gone away. Mission Planner emits a GCS message say “AUTO Trigger Switch On/Off” (something around those lines) - but the rover just continues to move along in AUTO mode regardless of the switch’s state.
Anyone have any luck with this feature on a semi-recent version of ArduRover?
The auto mission works - its just that the start/stop switch does not disable power to the motors (like described in the Wiki). I had it working on an older firmware version - updated to 4.1.5 - now it is no longer working.
Sounds good - do you know a way to read GCS messages in Lua? I was thinking I could write a quick fix for now by just reading GCS message and waiting for that message to appear - then triggering AUTO mode.
So basically I am deploying this rover from a drone (winching it down). When the rover hits the ground it flips a switch - when that happens it should begin a pre-loaded auto mission. So basically during flight I have it in hold mode - and then when it hits the ground it flicks the switch and is put into AUTO mode.
I have played around with having a breach height via Lua.
Once the vehicle has gone above 25’ it goes into a function where it is constantly checking to see if it has been deployed. Once that altitude returns below 25’ it puts the rover into AUTO. I never go below 100’ during my flight - so I think 25’ is a safe measurement that won’t accidently breach.
But - I would like to continue with use of this switch if possible.
Yes - that is what I am looking at now. Just don’t know how to poll for the switch position in Lua… Somehow ArduRover knows so it must be somewhere. I have the switch hooked up to AUXOUT1 on Cube - and not seeing anything change on CH9_OUT when the switch triggers.
