I’m trying to get rover running on a BeagleBoneBlue following the quick start guide (BeagleBone Blue — Rover documentation). Unfortunately I can’t establish a connection with Mission Planner since the ardurover.service starts with a failure:
● ardurover.service - ArduRover Service
Loaded: loaded (/lib/systemd/system/ardurover.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Tue 2024-03-19 19:00:40 UTC; 89ms ago
Process: 1103 ExecStart=/usr/bin/ardupilot/ardurover -C /dev/ttyO1 -A udp:192.168.0.10:14550 -B /dev/tt Main PID: 1103 (code=exited, status=1/FAILURE)
I’m pretty new to Linux, so every help would be very much appreciated.
Hi @plambrec
First of all, your beagle is not running ardurover once there is a FAILURE status.
You need to check this one first - use systemctl status ardurover.service
Second one I don’t know what is your network topology so, how are you connecting to your beagle ? using the usb port or in your wifi network?
If is your ground control a windows machine disable your firewall.
Hi @juvinski,
Thanks a lot for your fast reply, I really appreciate it!! The ardurover service is definitely not running.
‘systemctl status ardurover.service’ gives me:
Active: activating (auto-restart) (Result: exit-code) since Tue 2024-03-19 19:04:41 UTC; 1s ago
Process: 1296 ExecStart=/usr/bin/ardupilot/ardurover -C /dev/ttyO1 -A udp:192.168.0.10:14550 -B /dev/tt Main PID: 1296 (code=exited, status=1/FAILURE)
Mar 19 19:04:42 rover systemd[1]: ardurover.service: Service RestartSec=1s expired, scheduling restart.
Mar 19 19:04:42 rover systemd[1]: ardurover.service: Scheduled restart job, restart counter is at 264.
Mar 19 19:04:42 rover systemd[1]: Stopped ArduRover Service.
Mar 19 19:04:42 rover systemd[1]: Started ArduRover Service.
Mar 19 19:04:42 rover ardurover[1300]: /usr/bin/ardupilot/ardurover: /lib/arm-linux-gnueabihf/libc.so.6:
Mar 19 19:04:42 rover systemd[1]: ardurover.service: Main process exited, code=exited, status=1/FAILURE
Mar 19 19:04:42 rover systemd[1]: ardurover.service: Failed with result ‘exit-code’.
How to check what is preventing the service from running?
About the connection to the BeagleBone I’m using wifi.
First disable the ardurover service to run with stop or disable it.
Second I recommend run using command line like
And check what is the error but for the cut you send I believe you downloaded ardurover from somewhere because what is appearing is a problem with libc (Mar 19 19:04:42 rover ardurover[1300]: /usr/bin/ardupilot/ardurover: /lib/arm-linux-gnueabihf/libc.so.6) but I need the complete line to check.
debian@rover:~$ sudo /usr/bin/ardupilot/ardurover -C /dev/ttyO1 -A udp:192.168.0.10:14550
sudo: unable to resolve host rover: Name or service not known
/usr/bin/ardupilot/ardurover: /lib/arm-linux-gnueabihf/libc.so.6: version GLIBC_2.33' not found (required by /usr/bin/ardupilot/ardurover) /usr/bin/ardupilot/ardurover: /lib/arm-linux-gnueabihf/libc.so.6: version GLIBC_2.32’ not found (required by /usr/bin/ardupilot/ardurover)
First of all thanks a lot for the detailed information!! I got up to the point ‘./waf’ and get and got a message to install empy==3.3.4:
debian@beaglebone:~/ardupilot$ ./waf
Waf: Entering directory `/home/debian/ardupilot/build/blue’
you need to install empy with ‘python -m pip install empy==3.3.4’
After successful install of empy ==3.3.4 I get the following:
debian@beaglebone:~/ardupilot$ python -m pip install empy==3.3.4
Looking in indexes: Simple index, piwheels - Simple index
Requirement already satisfied: empy==3.3.4 in /home/debian/.local/lib/python2.7/site-packages (3.3.4)
It worked with python3 and the build in the BBB was successful.
BUILD SUMMARY
Build directory: /home/debian/ardupilot/build/blue
Target Text (B) Data (B) BSS (B) Total Flash Used (B) Free Flash (B) External Flash Used (B)
bin/antennatracker 1268994 51396 58668 1320390 Not Applicable Not Applicable
bin/arducopter 1808856 82148 74440 1891004 Not Applicable Not Applicable
bin/arducopter-heli 1794632 83200 75272 1877832 Not Applicable Not Applicable
bin/arduplane 1799632 84132 73364 1883764 Not Applicable Not Applicable
bin/ardusub 1572580 67324 70032 1639904 Not Applicable Not Applicable
bin/blimp 1186740 49228 58832 1235968 Not Applicable Not Applicable
bin/ardurover 1626836 72424 74452 1699260 Not Applicable Not Applicable
Build commands will be stored in build/blue/compile_commands.json
‘build’ finished successfully (6h19m34.286s)
Nevertheless when starting the ardurover service it still does not work:
debian@beaglebone:~$ sudo systemctl status ardurover.service
Active: activating (auto-restart) (Result: exit-code) since Mon 2024-03-25 03:08:30 UTC; 552m Process: 1344 ExecStart=/usr/bin/ardupilot/ardurover -C /dev/ttyO1 -A udp:192.168.0.10:14550 - Main PID: 1344 (code=exited, status=203/EXEC)
Have you copy the file ardurover under build/blue/bin to /usr/bin/ardupilot/ardurover ?
Try inside the folder (build/bin/ardurover I think) run manually the ardurover program with the parameters
./ardurover -C /dev/ttyO1 -A udp:192.168.0.10:14550
Yes, I copied ardurover to /usr/bin/ardupilot/ardurover.
I tried to run it manually as you suggested and it worked using superuser privileges.
How to start it at boot automatically?
Sorry for not answering sooner. By accident I dropped the BBB and the USB connector was ripped of the board, so I had to solder on a new one first.
I tried the instructions at the last link you’d posted, but ardurover still doesn’t want to start at boot. As well I tried the instructions at BBBMINI/doc/software/software.md at master · earsneyes/BBBMINI · GitHub, but no luck so far. The only way is to start it manually with ./ardurover -C /dev/ttyO1 -A udp:192.168.0.10:14550. Any idea what I could try next? Thanks a lot!
what is the return of the
systemctl status <service_name.service>
? have you checked the dmesg to see a problem?
When you try systemctl start <service_name.service> the ardurover start ?
the return of systemctl status ardurover.service is the following:
Active: activating (auto-restart) (Result: exit-code) since Sun 2024-03-31 23:30:57 UTC; 1s ago
Process: 1473 ExecStart=/usr/bin/ardupilot/ardurover -C /dev/ttyO1 -A udp:192.168.0.8:14550 -B /dev/ttyS2 (code=exited, status=2 Main PID: 1473 (code=exited, status=203/EXEC)
Mar 31 23:30:58 beaglebone systemd[1]: ardurover.service: Service RestartSec=1s expired, scheduling restart.
Mar 31 23:30:58 beaglebone systemd[1]: ardurover.service: Scheduled restart job, restart counter is at 413.
Mar 31 23:30:58 beaglebone systemd[1]: Stopped ArduRover Service.
Mar 31 23:30:58 beaglebone systemd[1]: Started ArduRover Service.
Mar 31 23:30:58 beaglebone systemd[1476]: ardurover.service: Failed to execute command: Permission denied
Mar 31 23:30:58 beaglebone systemd[1476]: ardurover.service: Failed at step EXEC spawning /usr/bin/ardupilot/ardurover: PermissionMar 31 23:30:58 beaglebone systemd[1]: ardurover.service: Main process exited, code=exited, status=203/EXEC
Mar 31 23:30:58 beaglebone systemd[1]: ardurover.service: Failed with result ‘exit-code’.
In the ring buffer I could not find any further information. Starting the ardurover service and following status request gives me:
Active: activating (auto-restart) (Result: exit-code) since Sun 2024-03-31 23:35:09 UTC; 449ms ago
Process: 1690 ExecStart=/usr/bin/ardupilot/ardurover -C /dev/ttyO1 -A udp:192.168.0.8:14550 -B /dev/ttyS2 (code=exited, status=2 Main PID: 1690 (code=exited, status=203/EXEC)
You must change the mode or user.
You are having permission denied error - try chmod +x
