Rover-4.7.3 released!
Rover-4.7.3 has been released as the stable/official version for rovers and boats and can be downloaded using Mission Planner, QGC or directly downloaded from firmware.ardupilot.org.
The list of changes vs 4.7.2 are in the ReleaseNotes and copied below.
  1. Board specific changes
  • AEDROXH7 board updated for new pinout (@Aedrox-UAx, PR:34751)
  • SVehicle-E2-mini board support (@yannis-zhi, PR:33328)
  • TBS_LUCID_H7 variants support DPS368 or BMP390 baro (@andyp1per, PR:34431)
  • TBS_LUCID_H7_WING variant with MPU6000 IMUs (@andyp1per, PR:34629)
  1. Library/Driver changes
  • Aeron Systems PLX3 external AHRS driver (@VinayakPundhir, PR:33041, PR:34280)
  • BLHeli pass-through interrupt storm lockup and corruption fixed (@tridge, PR:34598)
  • CADDX gimbal holds body-frame lock mode for 5 seconds after first packet (@Hwurzburg, PR:34524)
  • Camera servo zoom and focus speeds configurable with CAMx_ZOM_RAT_MAX and CAMx_FOC_RAT_MAX parameters (@Williangalvani, PR:34428)
  • Inertial sensor logs every filtered gyro sample when the rate thread is decimating (@andyp1per, PR:34601)
  1. Copter specific fixes and minor enhancements
  • CONDITION_YAW with absolute angle fixed when WP_YAW_BEHAVIOR = 0 (@tzi4, PR:33942)
  • PosHold brake-entry threshold units fixed (@FurkanKY, PR:34624)
  • Vibration compensation throttle response fixed (@peterbarker, PR:34607)
  • Loiter coordinated turns disabled by default (@rmackay9, PR:34542)
  1. Sub specific changes
  • Joystick roll and pitch input scaling fixed (@ES-Alexander, PR:34551)
Thanks to the developers and beta testers who contributed to this release!
