First have a check over this. Be aware the Max Window value that I specify is linked to baud rate, so if you dont change baud rate then dont change the Max Window.
Your frequencies shown there (and number of channels) indicate an RFD868 pair of modems - the baud rate will be more limited than what I’ve indicated in that guide for 900 modems.
I’m wondering if only one channel is the issue
