RFD900x only - no transmitter
to make things easier you can create a rc link on your rfd900x on the ground side then use the gpio1 pin to port that rc signal back to the flight controller on the air side easy setup and only require an additional 2 wire connection on the flight controller side while keeping the rc link close to the radio at all times.
