Hi everyone, first time posting and no doubt lots to come.
Current setup is a H743 with RFD900x telemetry radios.
I would like to be able to complete a short flight completely autonomously, auto take off and land with a few waypoints in between.
I have searched on this forum as well as more broadly, is it possible to setup and fly without a regular transmitter? I would like to be able to load mission plan via telemetry radio or usb and then complete a short flight.
Has anyone does this before or have any advice about how I might go about it? Thanks in advancd.
Thanks geofrancis, really helpful information. That got me looking further into the flight modes and what they actually do.
With a requirement to have autotune run for efficient flight and to allow full control rates and as you said a neccesity.
Plan now will be to either arm from MP or shake to wake with a joystick via usb that will be able to switch between auto, autotune and probably RTL mode and fly the aircraft through an autotune cycle and utilise the rfd900 as the data carrier.
You need conventional RC control at least for set up and tuning, and most people would say even when running Auto missions in case you need to take control.
You will need a 3 position switch with Stabilize, AltHold and Loiter.
You will need to practice control on Stabilise mode as you will need this mode if something goes wrong.
After the craft is flying well in all modes and situations you can more safely run Auto missions.
to make things easier you can create a rc link on your rfd900x on the ground side then use the gpio1 pin to port that rc signal back to the flight controller on the air side easy setup and only require an additional 2 wire connection on the flight controller side while keeping the rc link close to the radio at all times.
